I recently started experimenting with custom sensors using ESPHome and have found it incredibly rewarding. By leveraging the ecodan-heatpump package, I’ve been able to create a more tailored setup for my smart home. However, I ran into a bit of a snag when trying to reuse existing sensors for calculations. After some trial and error, I discovered that using template sensors with lambda expressions was the key to achieving what I wanted. It was a great learning experience, and I’m excited to share some of the tips I picked up along the way!
- Understanding Sensor Integration: Start by thoroughly reviewing the sensor definitions in your package. This helps in identifying which sensors can be repurposed for custom calculations.
- Template Sensors: Don’t shy away from template sensors. They allow for dynamic calculations and can be incredibly powerful when combined with lambda functions.
- Debugging Tips: If you encounter issues like
NaNstates, ensure that the entities you’re referencing are correctly identified and that their values are being read properly.
I’d love to hear from others who have successfully implemented custom sensors or have tips for optimizing automation workflows. Let’s keep the conversation going and help each other make the most out of our smart home setups! ![]()
