Exploring Deep Sleep Functionality on ESP32 with ESPHome
Hey everyone, I’m diving into the world of ESP32 and ESPHome, and I’m really excited about the possibilities they offer. One thing I’ve been trying to figure out is how to implement deep sleep functionality. The goal is to have my ESP32 go to sleep at a specific time and wake up on its own either at another set time or when a solar module stops charging the battery. I’ve read through the ESPHome documentation, but I’m still not quite getting it to work as intended.
I understand that deep sleep is crucial for minimizing power consumption, especially for projects that rely on battery power. The ESP32 has an onboard RTC (Real-Time Clock) chip, which should make scheduling sleep and wake cycles straightforward. However, I’m running into some hurdles when trying to set this up without relying on external tools like Node-RED or automations.
One thing I’m curious about is whether there are any specific configurations or code snippets that others have found successful. For example, how do you ensure that the ESP32 wakes up reliably at the designated time without any external triggers? Also, I’m wondering if there are any best practices for handling the transition between sleep and wake modes without causing instability in the system.
I’ve also been experimenting with different power management settings and GPIO configurations to see if that makes a difference. It would be great to hear from anyone who has successfully implemented deep sleep on their ESP32 projects and what steps they took to make it work seamlessly.
In the meantime, I’ll keep tweaking the settings and trying out different approaches. I’m hopeful that with a bit more research and some trial and error, I’ll be able to get this working perfectly. Thanks in advance for any insights or advice you can share!
