I’ve been experimenting with tracking device states and automating actions based on those states. It’s fascinating how much control you can have over your smart home setup once you dive into the details. For instance, I recently set up a rule where my lights dim slightly if the room temperature drops below a certain threshold. It’s a small tweak, but it makes a big difference in comfort.
One thing I’m curious about is whether there’s a way to track not just the state of a device but also how it changed. For example, knowing whether a light was turned on manually or via a routine could open up new possibilities for automation. I’ve seen some discussions about using device state affector properties, but I’m not entirely sure how to implement that. If anyone has experience with this, I’d love to hear your insights!
Another area I’ve been exploring is setting up more complex automations. I recently tried creating a rule where my coffee maker turns on if I wake up before a certain time, but I ran into some issues with timing. It seems like the rule works perfectly in the morning but not consistently at other times. I’m wondering if there’s a better way to structure these automations for reliability.
I’d also love to hear about your favorite smart home hacks or automation setups. What small changes have made a big impact for you? Let’s share and learn together!
