Hello everyone! I wanted to share my recent experience setting up the Pimoroni Badger 2040W with ESPHome. It’s been an exciting journey with a few bumps along the way, but I’ve learned a lot through the process.
Getting Started
I started by following some basic ESPHome configurations for the Pi Pico, but the display integration was a mystery. After some research, I found that the GPIO pin setup was crucial. I spent hours tweaking the configuration file, adjusting pins for the display, and trying different models to match the Badger’s specs.
The Challenges
One issue I faced was the display not updating at all. The screen remained static, showing only the Pimoroni examples. I tried various display drivers and even checked the circuit diagram to ensure the pins were correctly inverted. Despite all this, the display stubbornly stayed the same.
Debugging the Display
I noticed error messages in the logs about a timeout while displaying the image. This led me to investigate the SPI communication settings. After some trial and error, I realized the update interval might be too aggressive for the display. I adjusted the update_interval to a more reasonable value, which helped stabilize the display updates.
GPIO and Button Functionality
Another aspect I explored was the GPIO functionality. The Badger has several buttons, and I wanted them to trigger specific actions. I set up binary sensors for each button and used lambda functions to update the display when a button was pressed. This was a great way to see the hardware and software working together in real-time.
Lessons Learned
This project taught me the importance of thorough documentation and community support. I found some fantastic resources on GitHub and the ESPHome forums that helped me troubleshoot. I also learned that sometimes stepping back and simplifying the configuration can lead to breakthroughs.
Overall, integrating the Pimoroni Badger with ESPHome has been a rewarding experience. It’s a powerful combination that opens up endless possibilities for custom displays and IoT projects. I’m already brainstorming my next project with this setup!
If anyone has tips or tricks for optimizing the display performance, I’d love to hear them. Happy coding and tinkering! ![]()
