Exploring ESPresence for Enhanced Home Monitoring
I recently stumbled upon ESPresence while browsing YouTube, and it immediately caught my attention. The idea of using BLE (Bluetooth Low Energy) to track objects inside my house seemed innovative and perfect for my setup. I decided to give it a try, and I must say, the results have been fascinating!
My Setup and Initial Impressions
I purchased a couple of ESPresence sensors and placed them in my living room and playroom. My goal was to automate my TV remote dashboard, which controls different devices based on my location. Previously, I had to manually switch the room location, but ESPresence promised a more seamless experience.
Within an hour of setting it up, I noticed how quickly it detected when I moved from one room to another. It was almost instantaneous compared to my previous setup, which relied on manual input. However, I did notice a slight delay when moving from the living room to the playroom. I’m still experimenting with placement to optimize this further.
Battery Life and Beacon Usage
One concern I had was battery life since I wanted to avoid frequently recharging my phone. To mitigate this, I decided to attach a thin BT beacon to my phone. This setup has significantly reduced battery drain while maintaining reliable connectivity with the ESPresence sensors.
I integrated ESPresence with my existing Home Assistant setup using Node-RED. Whenever the sensor detects a change in location, it updates a virtual Omni Sensor in Home Assistant. This integration allows me to automate various actions, such as turning on specific lights or adjusting the thermostat based on my current room.
Tips for Getting Started
If you’re considering ESPresence, here are a few tips:
  • Placement Matters: Position sensors in areas where you spend the most time to ensure optimal detection.
  • Use Beacons: If you’re concerned about battery life, attaching a beacon to your phone can help maintain connectivity without draining your battery.
  • Experiment with Placement: Don’t be afraid to move sensors around to find the best configuration for your space.
ESPresence has been a game-changer for my home automation setup, and I’m excited to see how it continues to evolve. If you’re looking for a more intelligent way to monitor and control your home, I highly recommend giving it a try!
