I recently came across the new display methods for Govee Curtain Lights (models H70B3, H70B4, H70B5) and I must say, they’ve taken my lighting design to the next level! The introduction of Layer, Carousel, and Combo effects has opened up a world of creative possibilities. Let me share my experience and some tips for those looking to dive into these features.### Layer Effect: Painting with LightThe Layer effect allows you to overlay different light effects, creating a dynamic and layered display. For instance, I tried creating a ‘Swimming Duck’ scene by overlaying a blue water ripple effect on one layer and a yellow duck on another. The result was absolutely magical! The duck appeared to float across the water, all thanks to the smooth transition between layers. This method is perfect for adding depth and movement to your designs.### Carousel Effect: Seamless AnimationsThe Carousel effect lets you play each layer in sequence, creating a seamless animation. I experimented with a ‘Bouncing Pumpkin’ effect by painting each movement of the pumpkin on separate layers. Setting the display duration to 0.5 seconds gave it a smooth, bouncing motion. This feature is ideal for festive occasions, where you can create animated scenes that really bring your space to life.### Combo Effect: Mastering DynamicsThe Combo effect combines both Layer and Carousel features, allowing you to set foreground and background effects independently. I created a ‘Christmas Card’ effect by painting a Christmas tree on the background layer and adding a firework effect in the foreground. The result was a festive and vibrant display that perfectly captured the holiday spirit. This method is great for layered animations with intricate details.### Getting StartedTo access these features, navigate to the ‘Advanced’ settings in the Govee app. You’ll find the new display methods under the ‘+’ icon in the DIY section. For those on Android, ensure your app is updated to version 6.5 or higher to fully enjoy these features.### Tips for Success1. Experiment with Layers: Start with simple designs and gradually add layers to build complexity.2. Adjust Speed and Timing: Play around with the speed and display duration to achieve the desired effect.3. Share Your Creations: The Govee app allows you to share your designs in the DIY section, so don’t hesitate to showcase your work!### Community FeedbackI’ve seen some fantastic examples of these new features in action. One user created a stunning ‘Ocean Waves’ effect using multiple layers, while another designed a ‘Firework Display’ that lit up their entire room. The possibilities are truly endless!If you’re looking to elevate your lighting design, I highly recommend exploring these new display methods. They’ve added a whole new dimension to my smart home setup, and I’m excited to see what creative designs the community comes up with next!Let me know your thoughts or if you’ve tried these features yourself—I’d love to hear about your experiences!
