Hello fellow smart home enthusiasts! I wanted to share my recent experience installing Govee RGBIC light strips, as it’s been quite an enlightening journey. If you’re considering adding these vibrant lights to your space, you might find some of my tips and insights helpful!
The Setup
I recently purchased Govee RGBIC strips to enhance the ambiance of my home, particularly in areas where I wanted dynamic lighting without the bulk of traditional fixtures. My goal was to install them in crown mouldings to create a seamless, modern look without compromising on functionality.
Challenges and Solutions
One of the initial hurdles I faced was dealing with the length of the strips. My room required a total of 45 feet, and the closest available strip was 49.2 feet. This left me with about 2 feet of excess on each end. I was hesitant to cut the strips, as I’d heard stories of people damaging their strips by cutting at the wrong points. However, after some research and experimentation, I found a workaround that worked perfectly!
Tip #1: Cutting with Care
If you find yourself with excess strip length, cutting at the designated divider points is the safest bet. I carefully cut the strips at these points and tested them afterward to ensure they still functioned as intended. The key here is precision and patience—take your time to avoid any accidental damage.
Tip #2: Hiding Excess with Style
For those who prefer not to cut their strips, hiding the excess under heat-resistant foil tape is a clever solution. I opted for this method, placing the foil loosely over the excess strips to prevent any unwanted light spillage. This approach also helps manage heat buildup, ensuring the strips operate safely.
General Installation Tips
- Measure Twice, Cut Once: Accurate measurements are crucial to avoid unnecessary waste or additional costs.
- Use Adhesive Backing: Ensure the strips are securely attached to prevent any shifting over time.
- Test Before Hiding: Always test the strips to confirm they’re working correctly before concealing them.
My experience with Govee RGBIC strips has been overwhelmingly positive. They’ve transformed the lighting in my home, offering versatility and a touch of elegance. Whether you’re a seasoned installer or a first-time user, with a bit of planning and the right tools, you can achieve a stunning result!
If anyone has additional tips or has tried alternative methods, I’d love to hear about them! Let’s continue to inspire and learn from each other as we enhance our smart homes. Happy installing! ![]()
