Hey everyone! I’ve been diving into the world of Home Assistant lately, and I wanted to share some of my experiences and insights. If you’re new to this, you might be wondering about the different ways to install Home Assistant. I’ve been researching the dedicated Home Assistant OS install versus the supervised install. From what I understand, the main difference is the managed OS feature. A dedicated install gives you full control over the system, while a supervised install is more streamlined and easier to manage, especially if you’re using it on a Raspberry Pi. I’m leaning towards the supervised install since it seems more user-friendly, but I’d love to hear others’ experiences!
Speaking of Raspberry Pi, I’ve been experimenting with setting up a supervised instance on Debian 11. It’s been a bit of a learning curve, but I’ve found some great guides that made the process smoother. If anyone has tips on optimizing performance or troubleshooting common issues, I’d appreciate it!
On another note, I’ve been exploring ways to integrate my smart home devices more effectively. For example, I’ve been trying to set up a rule that triggers my heater when there’s an overproduction of solar energy. It’s a bit tricky, but I’ve been using the Forecast.Solar plugin to predict energy output. Here’s a snippet of my current rule setup:
yaml
alias: PV overproduction - start
description: start switch when I have solar over-production
trigger:
- platform: event
event_type: state_changed
event_data:
entity_id: binary_sensor.exporting_power
condition: - condition: and
conditions:- alias: over-production > 1000 W
condition: numeric_state
entity_id: sensor.export_power
value_template: “{{ -(state.state | float) }}”
above: “1000” - alias: heat boiler is OFF
entity_id: sensor.heat_boiler_state
below: “0.5”
enabled: false
action:
- alias: wait to confirm that over-production is really here
delay: hours: 0 minutes: 2 seconds: 0 milliseconds: 0 - alias: heat boiler becomes ON
service: rest_command.com_bouton
data:
item: 1
enabled: false
Unfortunately, it’s not triggering as expected. Does anyone have experience with similar automations? Any advice would be greatly appreciated!
Lastly, I wanted to share a fun project I’ve been working on. I recently acquired the Philips Hue Gradient lightstrip and have been trying to sync it with my monitors. It’s been a bit of a puzzle, but I’ve managed to get it working by adjusting the settings in the Hue app. If anyone else is struggling with this, feel free to reach out—I’d be happy to help!
Overall, I’m really enjoying the journey of building my smart home ecosystem. It’s a mix of challenges and triumphs, but every step brings me closer to my goal of a fully integrated, energy-efficient home. Let me know if you have any questions or tips to share!
Cheers,
