Exploring Home Assistant on Raspberry Pi and Reverse Proxy Setup
Recently, I’ve been diving into the world of smart home automation, and I must say, it’s been an exciting journey. I decided to set up Home Assistant on my Raspberry Pi, but I wanted to do it without reinstalling the entire OS. After some research, I found that it’s possible to install Home Assistant on top of an existing Buster OS installation. This approach saved me a lot of time and allowed me to keep my preferred settings intact. **I recommend checking out the official documentation for a smooth installation process.**One of the challenges I faced was setting up a reverse proxy using Caddy. I was torn between installing it as a separate VM or integrating it directly into Home Assistant. After some consideration, I decided to go with a separate VM. This setup not only enhances security but also makes managing other Proxmox VMs more straightforward. **Caddy’s ease of use and low resource consumption made it the perfect choice for my setup.**Another hurdle I encountered was dealing with fluctuating IP addresses for my cameras. After some troubleshooting, I realized the issue stemmed from DHCP reserved addresses conflicting with my network setup. **Switching to a static IP resolved the problem entirely, ensuring consistent connectivity.**Throughout this project, I’ve been impressed by the flexibility of Home Assistant and the wealth of resources available in the community. While there were a few bumps along the way, each challenge presented an opportunity to learn and improve my setup. I’m looking forward to further optimizing my smart home ecosystem and exploring more integrations in the future.
