Exploring Home Assistant on Raspberry Pi with Touchscreen
Hi everyone, I’ve been diving into the world of smart home automation with Home Assistant for about six months now, and it’s been a fantastic journey! I’ve managed to integrate a variety of sensors and devices, from monitoring the temperature in my fridge to tracking the CO2 levels in my living room. It’s truly amazing how much control and insight I’ve gained over my home environment.
Now, I’m looking to expand my setup by installing Home Assistant in a makerspace I run. The goal here is to monitor various parameters of our lasercutter, such as ventilation, cooling water temperature, and air assist pressure. The idea is to create a system that not only displays real-time data but also sends alerts when certain thresholds are breached. It’s a project that combines my love for tech with my passion for creating functional solutions.
To achieve this, I’ve decided to use a Raspberry Pi 3B paired with a 7-inch touchscreen. My challenge lies in figuring out the best way to set up Home Assistant alongside the touchscreen interface. From what I understand, there are several installation options available, such as Home Assistant Operating System, Container, Supervised, and Core. However, I’m a bit confused about which one would allow me to run both the Home Assistant server and the Lovelace GUI smoothly on the same device.
I’ve read through the official documentation and scoured the forums, but the information seems a bit fragmented, especially with the changes in OS names and supported systems. For instance, I’m trying to confirm whether installing a standard Raspberry Pi OS and then adding Home Assistant Supervised would be the right approach. I’m also curious about the performance of the Raspberry Pi 3B in this setup—will it handle both the server and the GUI without any lag?
If anyone has experience with this setup or can provide some clarity on the best practices, I’d be incredibly grateful! Whether it’s recommendations on the OS to use, tips on optimizing performance, or insights into the installation process, your input would be invaluable. Let’s make this project a success together!
Cheers,
Gavin
