I recently stumbled upon the Home Assistant Postfix Mail Forwarder add-on and decided to give it a try. This add-on allows you to set up a simple email forwarding service, which I found incredibly useful for managing emails from my custom domain. Here’s my experience and some tips for anyone looking to set it up.First, I installed the add-on through the Home Assistant add-on store. The installation process was straightforward, but I had to ensure that my domain’s MX record was correctly configured and that ports 25 and 587 were forwarded on my router. Initially, I faced a ‘Connect Time Out’ error, which I later discovered was due to my ISP blocking port 25. After contacting my ISP to remove the block, everything worked smoothly.One thing I found helpful was integrating this add-on with the Let’s Encrypt add-on for SSL certificates. This ensured that my email service was secure and compliant with modern standards. I also configured the forwarding preferences to route emails to my primary Gmail account, which made managing notifications from my domain much easier.For anyone planning to use this add-on, I recommend thoroughly checking your MX records and ensuring your router’s port forwarding settings are correct. If you encounter issues, the logs are a great resource for troubleshooting. Additionally, be mindful of potential limitations, such as the need for a PTR record for reverse DNS lookup, especially if you’re using Gmail.Overall, this add-on has been a fantastic addition to my Home Assistant setup, providing a reliable and customizable email forwarding solution. It’s definitely worth exploring if you’re managing a custom domain and want to streamline your email management.
