Hi all, I’m thrilled to share my journey into the world of home automation!
I recently set up a Zigbee network using the GLEDOPTO GL-C-103P controller and some WS2812B LED strips. It’s been an exciting project, though not without its bumps along the way. ![]()
One of the first challenges I faced was getting the LED colors right. Initially, the red and green were swapped, which was a bit confusing. After some research, I discovered that the LED strips use a GRB (Green, Red, Blue) color format instead of the usual RGB. Once I adjusted the settings in Home Assistant, everything fell into place! ![]()
Another aspect I’ve been exploring is integrating MQTT switches for controlling my sprinkler system. I set up a Raspberry Pi with a 4-relay board and wrote a Python script to handle MQTT commands. However, after a recent update, only the last switch in my configuration worked. It turned out I needed to restructure my MQTT configuration to ensure each switch had a unique ID. Now, all four sprinklers operate seamlessly! ![]()
I’m also curious about others’ experiences with firmware updates. I have an Inovelli switch that refuses to update, getting stuck at the transfer request. Has anyone encountered this and found a workaround? ![]()
Lastly, I wanted to share a tip for those using MariaDB with Home Assistant. Ensuring your database connections are stable can prevent crashes. I found that optimizing my queries and regularly backing up my database helped a lot! ![]()
Looking forward to hearing about your projects and tips! Let’s keep the conversation flowing! ![]()
