Exploring Home Security Automation with Shelly Flood and Homey Pro
Hi everyone, I wanted to share my recent experience setting up a home security system using the Shelly Flood sensor and Homey Pro. It’s been a learning journey, and I thought I’d walk through my process and some tips I picked up along the way.
The Setup
I’ve always been a bit anxious about water damage, especially after a few close calls during heavy rains. So, I decided to install the Shelly Flood sensor in my basement. It’s been a game-changer! The sensor is so easy to set up, and the fact that it works without a bridge is a huge plus for me. I integrated it with Homey Pro to handle the automation side of things.
Challenges and Solutions
At first, connecting everything was a bit tricky. I had to experiment with different Wi-Fi channels and settings on my router to ensure a stable connection. I remember one night where the sensor kept disconnecting, and I had to disable channels 12 and 13 on my 2.4 GHz network to get it working smoothly. It was frustrating at the time, but it taught me a lot about Wi-Fi optimization!
Automation Magic
Once everything was connected, I set up some automations. When the Shelly Flood detects water, it triggers an alert on my phone and sends an email. I also have it turn on some lights in the basement to help me quickly assess the situation. It’s comforting to know that I’ll be notified immediately if there’s a leak, even when I’m not home.
Tips for Others
If you’re looking to set up something similar, here are a few tips:
  • Location Matters: Place the flood sensor in areas prone to water damage, like near pipes or in basements.
  • Test Early: Run some tests to ensure your automations work as expected. I did a quick test with a small container of water, and it worked perfectly!
  • Consider Power Sources: Make sure your sensors are powered reliably. I opted for a USB power bank for mine to avoid any battery issues.
This project has given me peace of mind knowing my home is better protected. It’s also shown me how powerful smart home devices can be when integrated properly. I’m already brainstorming other ways to use my Homey Pro, like automating my garden lights or setting up a smarter energy monitoring system.
If anyone has questions or wants to share their own security automation setups, I’d love to hear about them! Happy automating! :blush:
