Exploring Hubitat's Rule Machine: A Deep Dive into Custom Triggers
I’ve been diving into the Hubitat Rule Machine lately, and it’s been an exciting journey! I’m particularly fascinated by the possibilities of creating custom triggers to automate my smart home setup. However, I’ve hit a bit of a snag that I’m hoping the community can help me work through.
So, here’s the setup: I’ve integrated a presence sensor (LD2420) with an ESP8266 running ESPHome. The sensor communicates with Hubitat via the MQTT Handler app, and everything works smoothly so far. The sensor’s payload fluctuates around 770-790 under normal conditions, but when someone walks nearby, the value drops below 500. My goal is to create a trigger that activates when the payload falls below 500. Sounds straightforward, right?
Here’s where the challenge comes in: I can’t seem to find a ‘less than’ option for my custom attribute in the Rule Machine. I’ve scoured the settings and documentation, but nothing stands out. I’m wondering if there’s a workaround or a different approach I can take to achieve this functionality. Maybe there’s a way to use a different attribute or a combination of conditions that I haven’t considered yet.
I’ve also noticed that the payload changes slightly all the time, which adds another layer to the problem. I need a trigger that’s both sensitive enough to detect the presence reliably and robust enough to ignore minor fluctuations. It’s a balancing act, to say the least!
I’m really excited about the potential of the Hubitat Rule Machine, and I’m determined to crack this puzzle. If anyone has experience with custom triggers or knows of a creative way to implement a ‘less than’ condition, I’d be incredibly grateful for your insights. Let’s brainstorm together and see if we can find a solution that works!
Thanks in advance to everyone who takes the time to share their thoughts. I’m looking forward to learning from the community and taking my smart home setup to the next level!
