Exploring KNX Binding and USB Support in OpenHAB
Hello OpenHAB enthusiasts! I’m diving into the world of KNX integration and have some thoughts and questions to share with you all. If you’re also exploring KNX or facing similar challenges, I’d love to hear your experiences!
My Journey with KNX Binding
I’ve been experimenting with the KNX binding in OpenHAB 2.2.0, aiming to streamline my home automation setup. The KNX2 binding has been a great tool, but I’ve encountered some puzzling behavior, particularly with USB interfaces. Let me walk you through what I’ve observed and what I’m curious about.
The Issue at Hand
From what I understand, the Calimero project, which the KNX2 binding is based on, supports USB interfaces. However, in my setup, the binding only recognizes serial and IP interfaces. This is a bit frustrating because I’d prefer to use a USB interface for its direct connection without the need for an IP tunnel.
I’ve noticed that several users have encountered timeout errors and Java exceptions when using IP tunnels, especially when the router doesn’t support the USB interface. It makes me wonder: why not access the USB interface directly if it’s on the same machine as OpenHAB? Wouldn’t that eliminate the need for IP tunneling and potential connection issues?
Seeking Solutions
I’ve explored various forums and documentation, but unfortunately, there’s no clear solution yet. Some users have resorted to workarounds like automatically restarting the KNX binding or disabling/enabling the Thing. While these fixes provide temporary relief, they’re not ideal for a seamless automation experience.
I’m curious if anyone has successfully modified the underlying Calimero files to support USB interfaces. If so, I’d love to hear about your approach and any challenges you faced. Additionally, I’d appreciate any insights into why the USB support isn’t natively included in the KNX2 binding and if there are plans to address this in future updates.
A Glimmer of Hope
On a positive note, I stumbled upon a discussion where someone mentioned purchasing a Gira IP interface as a workaround. While it’s not the solution I was hoping for, it’s reassuring to know that alternatives exist for those who need a reliable connection. I’m hopeful that with community input and developer attention, the USB support issue will be resolved in the near future.
The KNX binding has immense potential, and its ability to integrate with various devices is truly impressive. However, the current limitations with USB support are a hurdle that I, and many others, would love to overcome. I’m optimistic that with continued collaboration and innovation, we’ll see even more robust features in the KNX binding.
Thank you for reading, and I look forward to hearing your thoughts and experiences with KNX integration in OpenHAB!
Best regards,
