Exploring Low-Power Solutions for Fireplace Control
I’ve been diving into the world of smart home automation, and I’m absolutely thrilled with the possibilities it offers. One of my recent projects has been integrating a virtual thermostat with my fireplace, which also uses a virtual sensor and a Shelly Relay to control the fireplace. It’s been a fantastic setup, but I’ve been itching to take it to the next level by adding a wall-mounted controller.
My initial thought was to go with an e-Ink display device—it’s sleek, low-power, and perfect for a wall mount. However, after some research, I realized that finding a compact, battery-operated e-Ink solution for this specific use case is quite challenging. So, I started exploring alternatives.
I began considering a battery-operated thermostat. The idea is to use a low-power device that can communicate via Zigbee or Z-Wave to my Hubitat hub. Since sending an API call over Wi-Fi would drain the battery too quickly, a wireless protocol like Zigbee or Z-Wave seemed like the way to go. But here’s where I hit a snag—finding a low-power, battery-operated thermostat that fits this use case has been a bit of a puzzle.
I’ve reached out to the community to see if anyone has recommendations or experience with similar setups. I’m curious if there’s a device that can act as a virtual thermostat or control the fireplace directly via a wall-mounted interface. The ideal solution would be something that’s not only functional but also sleek and integrates seamlessly with my existing setup.
This journey has been a fascinating exploration of the possibilities and limitations of smart home technology. I’m excited to see what the community suggests and how we can collectively find a solution that ticks all the boxes. Thanks in advance for your insights and experiences—your input is invaluable!
Cheers,
