I’ve been diving into the world of Lua development for SmartThings, and it’s been quite the journey! As someone new to this, I wanted to share my experiences and see if others have encountered similar challenges or have tips to share.
The Setup
I started by installing Lua for Windows and downloaded the SmartThings libraries. Setting up the environment seemed straightforward at first—installing Lua, extracting the libraries, and configuring the LUA_PATH. But as I began experimenting, I ran into an issue when trying to require the st.capabilities module. The error pointed to a problem in st.utils.lua, specifically a syntax error near an ampersand. This was puzzling because the code seemed correct based on the documentation.
Debugging in VS Code
After some frustration, I decided to switch to Visual Studio Code. I added some specific settings to my .vscode/settings.json file to adjust the debug path, and to my surprise, the code started working in the debugger. This made me realize that perhaps running and debugging SmartThings Edge drivers locally isn’t the intended workflow. I’m now curious about how developers typically handle iterative coding and debugging without constantly deploying via the CLI.
Questions for the Community
- Remote Debugging: Is there a way to debug through the hub in real time? I’d love to know if there’s a remote debugging bridge available.
- Deployment Workflow: What strategies do you use to streamline the development and testing process? Are there tools or techniques that make iterative coding more efficient?
- Environment Configuration: Did I miss something in my initial setup? It’s possible I overlooked a library or configuration step that could have avoided this issue altogether.
Reflections
This experience has been both challenging and enlightening. It’s clear that setting up a development environment for Lua with SmartThings requires careful attention to configuration details. I’m hopeful that by sharing my journey, others might avoid some of the pitfalls I encountered. If anyone has insights or tips, I’d love to hear them!
Thanks for reading, and I look forward to the discussion!
