Hi everyone, I’ve been diving into the world of Modbus TCP for my temperature monitoring setup, and I wanted to share my experience and some lessons learned. ![]()
I recently switched from using MQTT to Modbus TCP for my Inveo Nano temperature meter. While the transition has been smooth, I encountered a minor hiccup with decimal precision. The temperature readings were only showing whole numbers, which was a bit puzzling. After some research, I discovered that the manufacturer stores the temperature multiplied by ten in a specific register. For example, 30.4°C is stored as 304. I tried adjusting the scaling in Home Assistant, but it didn’t quite work as expected. However, I realized that whole degree accuracy was sufficient for my needs, so I decided to stick with it. It’s been a great learning experience!
One key takeaway is the importance of restarting Home Assistant after making configuration changes to Modbus settings. I initially tried quick reloads, but they didn’t apply the changes properly. A full restart did the trick, saving me a lot of frustration. ![]()
Overall, I’m impressed with how cool and elegant Modbus TCP is. It’s opened up new possibilities for integrating various devices seamlessly. If you’re considering Modbus for your setup, I highly recommend exploring its capabilities—it’s definitely worth the time! ![]()
Any other Modbus enthusiasts out there? I’d love to hear about your experiences and tips! ![]()
