Hello everyone! I’ve been diving into the world of MQTT and automation lately, and I wanted to share some of my experiences and tips in case they can help others. First off, I’ve been working on configuring my alarm system via MQTT discovery. It’s been a bit of a learning curve, but I’ve managed to get it working smoothly. Here’s what I’ve learned:
Supported Features in MQTT Alarm Control Panel: I initially struggled with setting the
supported_featuresparameter correctly. After some research, I realized that each feature corresponds to a specific bit in the integer value. For example, if you want bothARM_AWAYandARM_NIGHT, the value should be6(sinceARM_AWAYis2andARM_NIGHTis4, and2 + 4 = 6). This was a bit confusing at first, but once I got the hang of it, it made setting up the alarm much easier. -
MQTT Discovery Configuration: I found that organizing the MQTT discovery payload clearly is crucial. Here’s an example of how I structured mine:
“name”: “Home”,
“unique_id”: “12345678_Home”,
“state_topic”: “alarm/12345678/state”,
“command_topic”: “alarm/12345678/command”,
“payload_arm_away”: “armed”,
“payload_arm_night”: “partial”,
“payload_disarm”: “disarmed”,
“supported_features”: 6,
“value_template”: “{{ value_json.security_level }}”,
“device”: {
“identifiers”: [“12345678”],
“manufacturer”: “Me”,
“model”: “Alarm”,
“name”: “Home”,
“sw_version”: “1.0”
“code”: 0000,
“code_arm_required”: false
This setup ensures that the alarm system integrates seamlessly with Home Assistant, and I can control it through MQTT messages.
- Automation Tips: I’ve also been experimenting with automations to enhance my home’s functionality. For instance, I set up a routine where my lights turn on 30 minutes before sunset if we’re both home. This has been incredibly convenient, especially during the shorter daylight hours of winter. Here’s a snippet of the automation I used:
yaml
- alias: Living Room Lamp - Sunset
trigger:- platform: sun
event: sunset
offset: “-00:30:00”
condition: - condition: state
entity_id: device_tracker.wife
state: home - condition: state
entity_id: device_tracker.me
state: home
action: - service: homeassistant.turn_on
entity_id: switch.living_room_lamp
- platform: sun
This automation checks if both of us are home before turning on the lights, which saves energy and ensures we only get the light when we need it.
- Community Resources: I’ve also found the community blueprints and shared automations to be invaluable. For example, there’s a fantastic blueprint for customizing actions on a Philips Hue Dimmer Switch, which allows you to assign different actions to each button press and hold. This has been a game-changer for me in terms of controlling my home environment more intuitively.
I’d love to hear about others’ experiences with MQTT configurations, automations, and any tips or tricks they’ve picked up along the way. Whether you’re a seasoned pro or just starting out, sharing knowledge helps us all improve our smart home setups!
Cheers,
