As a homeowner who’s deeply into automation, I’ve been exploring the capabilities of OpenHAB, especially with MQTT integration. It’s a fascinating journey, though not without its challenges. I recently upgraded my OpenHAB setup and encountered an issue with MQTT, specifically with door sensors. The logs were showing errors about unsupported commands, which was puzzling since everything worked fine before the upgrade. After some research, I realized that the ESP-01 firmware might need tweaking, but I’m still unsure if a JSON transformation could resolve the issue instead of reflashing the device. If anyone has insights on this, I’d greatly appreciate the help!
Another area I’ve been diving into is automation rules. I’ve set up a system where my Hue lights adjust based on circadian rhythms, but I want to disable this flow when I manually change the brightness. This works seamlessly with physical dimmers, but I’m struggling to replicate it via smartphone apps. It’s a minor inconvenience, but I’m determined to crack it!
On the data scraping front, I’ve been eyeing my internet usage statistics and would love to integrate them into OpenHAB. It’s a bit daunting since it involves logging into a secure site, but I’m optimistic that with some web development know-how, I can make it happen. If anyone has experience with similar projects, please share your approach!
Lastly, I’ve been contemplating a switch from OpenHAB to Home Assistant. While OpenHAB has been reliable, the growing community and extensive documentation around HA are tempting. I’m curious to hear others’ experiences with both platforms—specifically, how smooth the transition might be and what benefits HA offers that OpenHAB doesn’t.
This community is a goldmine of knowledge, and I’m excited to contribute my experiences while learning from others. Let’s keep the discussions flowing!
