Exploring MQTT and KNX Integration in OpenHAB
I’ve been diving into the world of home automation lately, and I must say, it’s been an exciting journey! I recently set up an MQTT broker to connect various smart devices around my home. While most things are working smoothly, I’ve encountered a peculiar issue with my MQTT switch integration. I’ve configured both the state and command topics, and while the state updates work perfectly, sending commands doesn’t seem to have any effect. I’ve tried troubleshooting by restarting the broker and checking the logs, but nothing stands out. It’s a bit puzzling, but I’m determined to figure this out!
On another note, I’ve also been exploring KNX integration for my smart home setup. It’s fascinating how KNX allows for such precise control over lighting and climate systems. However, I’ve noticed that every action I trigger through OpenHAB sends two identical telegrams on the bus. I’m not sure if this is a configuration issue or something else. I’ve tried adjusting the KNX settings and updating the firmware on my Gira IP Router, but the problem persists. I’m hoping someone in the community might have encountered this before and could offer some insights.
In the meantime, I’ve been experimenting with different configurations and documenting my findings. It’s a great way to learn and share experiences with others who are on a similar journey. If anyone has tips or tricks for optimizing MQTT or KNX setups, I’d love to hear them! Happy automating! :rocket:
