Exploring MQTT Dimmer Issues and Solutions in OpenHAB
Hello everyone, I recently upgraded to OpenHAB 4.3 and encountered a peculiar issue with MQTT dimmer items. The sliders for these dimmers no longer function in the graphical interface, though the system operates perfectly through rules and voice assistants. This problem is specific to MQTT dimmer items, as other bindings work flawlessly. I’ve tried creating new things and items, but the issue persists. Interestingly, numerical values update when adjusting via Zigbee2MQTT or group commands, but the slider knob remains static. It’s worth noting that the graduated scale is also missing. Before the upgrade, everything worked seamlessly. I’m curious if others have faced similar issues and if there are specific parameters or settings I should check. Any insights or troubleshooting steps would be greatly appreciated! Thanks in advance for your help and support. :pray:
