Exploring NFC Automation and Tuya Integration
Hi everyone, I’ve been diving into the world of NFC automation and Tuya integration, and I thought I’d share my experiences and some of the challenges I’ve encountered. Whether you’re a seasoned pro or just starting out, I hope this post can offer some insights or tips!
First off, I’ve been experimenting with NFC tags to trigger various actions around my home. It’s been a lot of fun setting up scenarios where a simple tap can control lights, adjust thermostats, or even switch modes. However, I ran into an interesting issue where my NFC automation was being triggered twice in a row. I’d scan the tag on my iPhone, and the automation would fire up twice, which was a bit frustrating. After some digging, I realized it might be related to how the iPhone and the HA app communicate. It’s a minor glitch, but it’s good to be aware of if you’re using NFC tags extensively.
On another note, I’ve been working with Tuya devices lately, specifically a thermostat. The integration has been smooth for the most part, but I noticed that certain data points weren’t being reported periodically. For instance, the power switch and target temperature values weren’t updating in Home Assistant unless I manually changed them. It was a bit puzzling, but I found a workaround by modifying the configuration to send raw commands when specific data points update. It’s a bit of a hack, but it’s kept things running smoothly.
I’d love to hear from others who have tackled similar issues or have tips for optimizing NFC automation and Tuya integrations. Whether you’re looking to streamline your setup or just curious about how others approach these challenges, let’s keep the conversation going!
Cheers,
