Exploring OpenHAB on Proxmox: My Journey and Insights
After spending quite some time researching the best way to install openHAB on my Proxmox setup, I thought I’d share my journey and some insights with the community. My hardware setup includes an Intel N100 mini PC with 16GB RAM and a 256GB NVMe SSD, running Proxmox VE 8.2.7. I’ve been using openHAB for years, particularly with the openHabian distribution on a Raspberry Pi 3, but I wanted to explore how it would perform on a more robust system like Proxmox.
I considered several installation methods:
  • Proxmox VE Helper-Scripts using an LXC container.
  • Docker with the official openHAB Docker image.
  • A Debian/Ubuntu installation on an LXC or VM, either manually or via the APT packages.
  • Using openHabian on an LXC or VM.
While I was initially drawn to openHabian due to my familiarity with it, I decided to go with the Proxmox VE Helper-Scripts approach for a few reasons. First, it seemed more streamlined for Proxmox environments. Second, the LXC container approach offers better resource management and isolation compared to a full VM. Lastly, the community support and documentation for this method appeared robust.
Here are some of my observations and lessons learned:
  1. Installation Process: The installation using the Helper-Scripts was surprisingly smooth. The scripts are well-documented and user-friendly, even for someone not deeply familiar with Proxmox internals. I appreciated the ability to customize the container settings before deployment.
  2. Performance: Running openHAB in an LXC container on Proxmox has been impressively stable. The system handles my current setup of around 50 devices without any noticeable lag. Resource utilization is also efficient, with openHAB averaging around 15% CPU usage and 800MB of RAM consumption.
  3. Configuration Flexibility: One of the standout features of this setup is the flexibility in configuration. I was able to tweak network settings, storage allocations, and resource limits to optimize performance for my specific use case. This level of control is something I couldn’t achieve as easily with a Raspberry Pi setup.
  4. Backup and Snapshots: Proxmox’s built-in snapshot and backup functionality has been a lifesaver. I can now easily create backups of my openHAB container, ensuring that any configuration changes or updates are safeguarded.
  5. Pain Points: The only minor hiccup I encountered was during the initial setup of the LXC container. I had to manually adjust some firewall rules to ensure proper communication between the container and my IoT devices. However, this was a one-time issue and was resolved with some quick research.
  6. Future Plans: Moving forward, I plan to experiment with integrating more advanced automation scripts and possibly even some custom rule templates. I’m also curious about leveraging Proxmox’s clustering capabilities to create a more resilient setup.
To anyone considering a similar setup, I’d recommend thoroughly reviewing the documentation for the Proxmox VE Helper-Scripts and spending some time understanding LXC container basics. While the setup might seem daunting at first, the payoff in terms of performance and flexibility is well worth the effort.
I’d love to hear from others who have set up openHAB on Proxmox—what approaches did you take, and what tips or tricks would you share? Let’s continue to learn and grow together as a community!
Cheers,
Eurico
