I’ve been diving into the world of smart cameras and automation, and I must say, it’s been an exciting journey! Let me share some of my experiences and insights in case they resonate with others or spark some ideas.
First off, I’ve been working with Presence 2 outdoor cameras. They’re fantastic for monitoring my property, but I’ve noticed an interesting behavior with their Wi-Fi connectivity. Despite having a robust mesh network with multiple access points, the cameras often connect to the weakest available signal. This leads to the app showing a weak Wi-Fi warning, which is a bit frustrating. I’ve tried restarting the cameras, and they temporarily connect to the nearest access point, but by the next day, they’re back to the weaker one. I wonder if there’s a way to tweak the firmware to ensure they stick with the stronger connection. Any thoughts or suggestions would be greatly appreciated!
On the automation front, I’ve been experimenting with setting up motion-only recording on my Wyze Outdoor Camera V2. While the Wyze Cam V3 makes this straightforward with a simple toggle in the settings, the V2 requires a bit more work. I ended up setting up scheduled recordings, but it’s not as seamless. I’m curious if others have found a more intuitive way to achieve motion-only recording on the V2 without the hassle of constant adjustments.
Another area I’ve been exploring is integrating different smart devices into a cohesive system. For instance, I’ve been trying to get my Aqara Cube T1 Pro to work seamlessly with my Sonoff ZBDongle-E. Initially, pairing was straightforward, but I noticed that only the ‘shake’ action was being recognized. After some research, I discovered that pressing the cube five times could unlock additional functionalities. It’s a small tweak, but it made a big difference in how I interact with my smart home setup.
I’ve also been impressed with the versatility of the Govee RGBIC strip, especially with the 5.1 update. While it’s a fantastic product, I’d love to have more control over the effects, such as customizing the flash colors independently. The current setup allows for some creativity, but there’s definitely room for more granular control, especially for someone like me who’s still learning the ropes.
Lastly, I’ve been experimenting with using PIR sensors in my kitchen to control the lighting. It’s been a learning experience figuring out the right settings to avoid false triggers, especially with the fluctuating temperatures during cooking. I’ve found that adjusting the sensitivity and using a combination of motion and presence sensors has helped create a more reliable system.
Overall, my journey with smart cameras and automation has been filled with both challenges and triumphs. The community support and resources available have been invaluable, and I’m excited to continue exploring and enhancing my smart home setup. If anyone has tips or experiences to share, I’d love to hear them!
