Exploring Smart Device Integration and Troubleshooting
As I dive deeper into the world of smart home automation, I’ve encountered a few intriguing challenges that I’d love to share and get some insights on. First off, I’ve been experimenting with ZigBee switches in my setup, but I’m hitting a snag where I can see the status updates but can’t control them from my hub. It’s a bit puzzling since the device communicates well otherwise. Any tips on device handlers or configurations that might help bridge this gap?
Another area I’m exploring is integrating a Shelly Dimmer into my lighting setup. While it works perfectly with a neutral wire, things get tricky without it. The dimmer flickers and disconnects when I try to calibrate it, which is frustrating. I’m wondering if there’s a workaround or a specific configuration that could stabilize the connection.
On the sensor front, I’ve been trying to get my Roborock vacuum’s battery level to show up as a sensor in my system. It’s visible in the device controls, but I need it accessible elsewhere. Does anyone know a straightforward way to mirror this attribute into a separate sensor?
Lastly, I’ve been curious about setting up static multicolor LED strips without any effects. It seems like it should be simple, but I’m not quite sure how to lock in the exact colors I want. Any advice on achieving a consistent, static multicolor setup would be a huge help!
I’m really enjoying the journey of customizing my smart home, and I’m grateful for the community’s support in tackling these challenges. Let’s keep the ideas flowing!
