I’ve been diving into the world of smart home automation lately, and I’ve got to say, it’s a fascinating journey! One of the projects I’ve been working on involves using ESPHome to set up a system that communicates via UART. It’s been a bit of a learning curve, but I’m really enjoying the process.
So, here’s a bit of what I’ve been up to. I’ve configured an ESP32 module to act as a bridge between my smart home hub and some custom-built devices. The idea is to send commands from my hub to these devices and receive status updates in return. The setup involves a bunch of template switches in ESPHome, each corresponding to a specific command that gets sent over UART. For example, I’ve got switches for setting different lighting modes, controlling curtains, and even managing fan speeds. Each switch sends a specific character over UART, which the connected devices interpret and act upon.
On the receiving end, I’ve set up a custom text sensor using a lambda function. This sensor listens for incoming data on the UART bus and updates the state of the corresponding switches based on the received characters. It’s a bit of a hack, but it works perfectly for my needs. The best part is seeing everything come together in the dashboard—flipping a switch in the app and watching the physical devices respond in real time is incredibly satisfying!
However, there’s been one persistent issue I’ve been trying to wrap my head around. While the sending and receiving of data works flawlessly in the logs, the changes aren’t always reflected in the dashboard. For instance, when a device sends back a status update, the corresponding switch doesn’t always toggle its state. I’ve tried tweaking the lambda function, adjusting the baud rate, and even reconfiguring the switches, but the problem remains. If anyone has any insights or suggestions, I’d be thrilled to hear them!
Another thing I’ve been experimenting with is integrating this system with Home Assistant. I’ve set up a few automations that trigger these UART commands based on events like sunrise/sunset or when certain smart home devices are activated. It’s been a great way to add a layer of customization that’s not readily available out of the box.
Looking ahead, I’m excited to continue refining this project. I’ve got a list of features I’d like to add, such as error handling for the UART communication and maybe even a web interface to monitor the data flow in real time. It’s projects like these that really showcase the power of open-source tools like ESPHome and the creativity of the community.
If anyone has similar projects or tips for improving this setup, I’d love to hear about them! Let’s keep the conversation going and help each other push the boundaries of what’s possible with smart home automation.
