Exploring Smart Home Automation with RGBW2 and LED Lighting
Hi everyone, I’ve been diving into the world of smart home automation lately and wanted to share some of my experiences and findings. If you’re into lighting setups, especially with RGBW2 controllers and LED lighting, you might find this interesting!
I’ve been experimenting with controlling LED lights using an RGBW2 Shelly device. It’s been a bit of a learning curve, but the results have been fantastic. For instance, I’ve managed to set up a system where 19 LED lights (5.5W each) are controlled through a single RGBW2. The setup uses a 12V power supply rated at 10A, which seems to handle the load without any issues. The Shelly itself is handling the dimming and color changes seamlessly, which is impressive!
One thing I discovered was the importance of proper wiring and ensuring that the ground connections are correctly managed. I initially had some flickering issues, but after adjusting the wiring and ensuring a clean ground connection, everything ran smoothly. It’s a small detail, but it makes a big difference in the overall performance.
For those looking to take it a step further, I’ve also explored using a NodeMCU with ESPHome to control individual LEDs. It’s a bit more complex, but the ability to program custom behaviors and integrate with other smart home devices is worth the effort. I’ve set up a system where LEDs change color based on room occupancy, which adds a nice touch to the ambiance.
I’d love to hear from others who have experience with similar setups. Have you tried controlling multiple LED lights through a single RGBW2 or NodeMCU? What challenges did you face, and how did you overcome them? Sharing experiences like these really helps the community grow and learn together!
Looking forward to your insights and tips. Let’s keep the smart home innovations flowing! :rocket:
