As a smart home enthusiast, I’ve been diving into the world of automation scripts and device integration. I recently set up a script to automate my window curtains using a Broadlink RM-Pro, and it’s been a fascinating journey! Here’s a quick rundown of my experience and some tips I’ve picked up along the way.
The Setup
I wanted to create a simple script to open and close my window curtains using voice commands. The Broadlink RM-Pro was the perfect device for this since it supports RF codes for controlling various appliances. I configured two scripts in my scripts.yaml file—one to open the curtains and another to close them. When I click the run button in the entity panel, everything works like clockwork!
The Challenge
However, things got tricky when I tried integrating this with my voice assistant. I wanted to say “fechar janela” (close window in Portuguese) to execute the corresponding script. But every time I tried, the assistant responded with “device or entity ‘janela’ does not exist.” After hours of troubleshooting and tweaking my configuration, I realized the issue was with how the script was linked to the device entity. Once I adjusted the alias and device naming, it started working seamlessly!
Tips for Others
- Double-Check Entity Names: Ensure your script aliases and device names match exactly what your voice assistant recognizes.
- Test Manually First: Always verify that your script works when triggered manually before integrating it with voice commands.
- Keep Scripts Organized: Use clear and descriptive names for your scripts to avoid confusion down the line.
The Outcome
Now, I can control my curtains with just my voice, and it’s incredibly satisfying to see everything work together so smoothly. This experience has inspired me to explore more automation projects around my home. Whether it’s adjusting the thermostat or turning on lights, the possibilities are endless!
If anyone has tips or tricks for optimizing voice-controlled scripts, I’d love to hear them! Happy automating everyone! ![]()
