I’ve been diving into the world of smart home automation lately, and I’m absolutely thrilled with how much I’ve been able to achieve so far. Let me share some of my experiences and insights with you all!
First off, I’ve been working on integrating my existing roller shutters into a more seamless smart home setup. Previously, I was using a Merten central switch alongside Jarolift TDR2C relays for local control. While this setup worked, it felt a bit outdated and limited in terms of integration with modern smart home ecosystems.
Enter the Shelly 2PM! I’ve been experimenting with replacing the local Jarolift relays with Shelly 2PM units. The idea is to have both central and local control while leveraging the Shelly ecosystem for enhanced functionality. So far, the installation has gone smoothly, and I’m impressed with how responsive the Shelly units are.
However, I’ve encountered a bit of a challenge in terms of wiring. Since the central control system and the local Shelly 2PM units are now separate, I need to ensure they’re properly connected through software. This means configuring the Shelly devices in a way that allows them to communicate with the central system without interfering with each other. I’m curious to hear if anyone else has tackled a similar setup and if there are best practices or tips to share!
On a different note, I’ve also been exploring the new firmware update for C-Bus controllers (V1.13.0). The improvements in scheduler functionality and error reporting are exciting, and I’m eager to see how these updates can enhance the reliability of my smart home setup. The bug fixes mentioned in the release notes are a huge plus, and I’m planning to update my controllers as soon as possible.
Another aspect I’ve been focusing on is optimizing my home’s energy efficiency. I’ve started experimenting with setting up a dawn-to-dusk sensor using a photo transistor and a modified Wyze contact sensor. The goal is to automate my outdoor lighting based on natural light conditions, eliminating the need for manual adjustments or relying on fixed schedules. While the project is still in its early stages, the potential to reduce energy waste and enhance convenience is thrilling.
I’d love to hear from others who are working on similar projects or have successfully implemented their own smart home automation solutions. What challenges have you faced, and what tips or tricks have you discovered along the way? Let’s keep the conversation going and help each other make the most of our smart home setups!
Cheers,
