Hello fellow smart home enthusiasts! I wanted to share some exciting updates and tips I’ve come across recently, along with a few questions I’ve been pondering. Let’s dive in!
Wyze Cam v3 and Robot Vacuum Updates
First off, I’m thrilled to hear that the Wyze Cam v3 and Robot Vacuum are making a comeback! For those who missed out earlier, Cam Plus subscribers get priority access and some great discounts. I’ve been eyeing the Cam Plus subscription myself, especially with the $25 discount on the Robot Vacuum. It’s a no-brainer for anyone looking to upgrade their home security and cleaning routine. If you haven’t subscribed yet, now might be the perfect time to jump on board!
Eufy Security Smart Lock
Speaking of upgrades, I’ve been using the Eufy Security Smart Lock Touch & Wi-Fi for a while now, and it’s been a game-changer. The fingerprint sensor and touch keypad are sleek, and the built-in Wi-Fi means I can lock and unlock from anywhere. While the fingerprint accuracy is almost there, Eufy support assures us firmware updates are on the way. Installation was a breeze, and the included parts are incredibly organized. My only wish? More integrations with platforms like Hubitat for better dashboard control.
Christmas Tree Water Monitor
This holiday season, I stumbled upon a clever project: a Christmas Tree Water Monitor. Using a Utilitech Z-Wave leak sensor, this app sends push notifications when the tree runs dry and can even turn off the lights until it’s watered again. I love how it uses existing sensors efficiently without draining batteries. It’s a perfect blend of tech and tradition!
EcoStruxure Machine Expert Twin
For those into digital twins, I’ve been amazed by how easy it is to add movement axes to 3D models in EcoStruxure Machine Expert Twin. By importing parts as separate meshes and assigning kinematic axes, you can quickly set up translational movements with limits. It’s a great tool for visualizing machine operations and could be a real asset for anyone working on custom projects.
Hiding Hue Bridge Behind Nginx
Security is always a concern, especially when sharing smart home access with family or guests. I came across a clever workaround for hiding the Hue bridge behind a reverse proxy using Nginx. This setup allows controlled access without exposing the bridge directly, which is a huge plus for security-conscious users. It’s a bit technical, but the guide I found made it manageable even for someone like me with intermediate skills.
Adding an External Antenna to Z-Wave Stick
Another project I’ve been eyeing is modifying a Z-Wave stick to add an external antenna. My house has thick concrete walls, and Z-Wave reception has always been hit or miss. By soldering an SMA connector and attaching a suitable antenna, I hope to boost reception significantly. The detailed guide I found makes it seem doable, though I’ll need to be careful with the soldering!
Community Forum Maintenance
Lastly, a quick heads-up: our community forum underwent some routine maintenance recently. Everything seems to be back to normal now, but if anyone experiences login issues, contacting support at support@hubitat.com should help.
I’d love to hear your thoughts on these topics! Have you tried any of these products or projects? Do you have any tips or tricks to share? Let’s keep the conversation going!
Happy smart home exploring!
Best regards,
