As I delved into the world of smart home automation, I found myself intrigued by the possibilities of integrating various devices. One of my recent projects involved connecting an ESP32 WROOM-32 module with a Grow R503 fingerprint sensor. While the idea seemed straightforward, the implementation turned out to be quite a challenge!
Initially, I configured the ESP32 with the fingerprint sensor, following the standard setup guide. However, I encountered a recurring issue where the board would crash after a few minutes of operation. The logs indicated a ‘LoadProhibited’ error, which was perplexing. After some research, I realized that the issue might be related to the sensor’s power supply or the way it was interfacing with the ESP32.
I decided to experiment with different power configurations, ensuring that both the main and touch induction power supplies were properly connected to the 3.3V rail. I also adjusted the UART baud rate and logging levels to minimize interference. To my delight, these tweaks stabilized the system, and the fingerprint sensor began functioning reliably without crashing.
This experience taught me the importance of meticulous hardware configuration and the value of community support. By sharing my journey, I hope to inspire others who are exploring similar projects. If you’re working on integrating sensors or microcontrollers, don’t hesitate to reach out—I’m happy to help!
Here’s a quick tip for anyone working with ESP32 and sensors: always verify your power connections and consider adjusting logging settings to prevent unexpected behavior. Happy tinkering! ![]()
