Hey everyone! I’ve been diving into the world of smart home integration lately and wanted to share some of my experiences and tips. Whether you’re a seasoned pro or just starting out, I hope this post can help you navigate some common challenges and discover new possibilities.
1. Deploying the Sony Binding with Compatibility in Mind
One of my recent projects involved deploying the Sony Binding via the community marketplace. I decided to create a kar file to streamline the installation process, avoiding the need to manually install features each time. Here’s the process I followed:
- Build Process: I used the latest 3.2.0-SNAPSHOT addons codebase and defined a
feature.xmlwith all necessary dependencies. The build command wasmvn clean install -pl :org.openhab.binding.sony karaf:kar. - Compatibility Issue: While the kar file worked seamlessly with the 3.2.0-SNAPSHOT runtime environment, it threw an error with the 3.2.0.M3 runtime. The error pointed to an issue with the repository definition in
feature.xml, specifically theohc.versionbeing set to3.2.0-SNAPSHOT. - Solution Exploration: I tried modifying the
ohc.versionin the Maven command but encountered issues with repository availability. Omitting the repository wasn’t an option as it resulted in a build failure. My question to the community is: Is there a way to build a kar file compatible with multiple OH runtime versions, such as milestones and SNAPSHOT builds? If so, what’s the best approach?
2. Debugging JavaScript Rules
Another area I’ve been exploring is JavaScript rules in OpenHAB. I recently created my first rule and encountered a challenge with logging. Here’s what I tried:
javascript
(function(i) {
var log = Java.type(“org.slf4j.LoggerFactory”).getLogger(“meteoalarm-wind”);
log(“the script is starting”);
var value = /.aw1([1-4])../.exec(i);
log.debug(“Value” + value);
if (value === null) {
return 0;
if (value[1] > 1 && value[1] < 5) {
return value[1];
return 0
})(input)
Despite my efforts, I couldn’t see any logs in openhab.log. After some research, I discovered that using Java.type("org.slf4j.Logger").getLogger("meteoalarm-wind") was the correct approach. I also ensured that the logging level was set appropriately in the configuration. If anyone has additional tips on optimizing JavaScript rules or logging, I’d love to hear them!
3. Customizing Button Card States
I’ve been working on a project where I use a button card to control door locks. Initially, the state was set to “off,” but I wanted to change it to “locked” for clarity. Here’s how I achieved it:
- Configuration: I modified the button card’s state mapping in the Lovelace configuration. By adjusting the
stateproperty and using avalue_template, I ensured that the card displayed “locked” when the lock was engaged. - Automation: I integrated this with an automation rule that triggers the lock action and updates the state accordingly. This made the interface more intuitive for my family.
If you’re looking to customize your button cards or automations, feel free to ask for advice!
4. Migrating Sonoff RF Bridge
I recently upgraded my Sonoff RF Bridge from v1.0 to R2 v2.2 and applied the Direct Hack along with esphome. However, I encountered issues with triggering my window shades. The RF signals from my remotes weren’t being detected, and replaying the captured events didn’t work either.
After some research and community support, I discovered that switching to remote_receiver dump = raw mode was necessary for compatibility with the R2 version. I also learned that using remote_transmitter.transmit_raw with the correct raw data format was essential for successful transmission.
If you’re facing similar issues, I recommend checking the raw event data and ensuring your transmission commands match the captured format.
5. Enumerating Chromecast Audio Devices
Another project I’m working on involves creating a dynamic list of Chromecast Audio devices. Initially, I relied on checking the supported_features attribute, which worked but felt a bit fragile. I reached out to the community for a more reliable approach and found that using the platform filter in Lovelace was a better solution.
Here’s the improved code I’m using now:
yaml
{% for state in states.media_player -%}
{%- if state.platform == ‘cast’ %}
{{ state.entity_id }}
{% endif -%}
{% endfor %}
This method is more robust and ensures that only Chromecast Audio devices are included in the list.
Conclusion
Smart home integration is an ever-evolving field, and I’m excited to continue learning and sharing my experiences. Whether it’s troubleshooting compatibility issues, optimizing JavaScript rules, or customizing button cards, the community’s support has been invaluable. If you have any questions or tips, feel free to drop them below—I’d love to hear from you!
Cheers,
