I’ve been diving into the world of smart home automation, and I must say, it’s been an exciting journey!
I recently acquired a Shelly Pro Dual Cover PM, and integrating it into my setup has been both rewarding and a bit challenging. Let me share my experiences and some tips I’ve picked up along the way.First, I wanted to integrate my Ziiip side roll blinds and a BleBox controller for my pergola. The goal was to control everything seamlessly through my smartphone using the Home Assistant app. The initial setup went smoothly, but I encountered an issue with the Shelly’s shutter mode and its limited runtime. After some research, I discovered that adjusting the runtime settings or using HTTP commands could help bypass this limitation. It was a bit of a puzzle, but figuring it out was satisfying!Another aspect I explored was enhancing my Home Assistant dashboard. I found that while the default color temperature slider was great, I missed the ease of use of a color wheel for selecting specific hues. I ended up creating a custom integration that combines both options, making it easier to switch between precise color temperatures and vibrant colors. This tweak has really elevated my smart lighting experience! ![]()
I also wanted to ensure energy efficiency by controlling my infrared heater via a relay. Initially, I thought the Shelly’s dual mode could handle this, but it turned out to be simpler to use one channel for the blinds and another for the relay. This setup keeps my heater powered off when not in use, which is a great way to save energy without sacrificing convenience.One thing I’ve learned is the importance of community support. When I faced issues with firmware updates and device compatibility, reaching out to forums and communities like this one was invaluable. The collective knowledge and willingness to help have been incredible, and I’m grateful to be part of such a supportive ecosystem.If you’re looking to integrate Shelly devices or enhance your Home Assistant setup, I encourage you to explore these tips and don’t hesitate to ask for help when needed. The journey might have its bumps, but the rewards are well worth it!
Happy automating, and here’s to creating a smarter, more connected home! ![]()
