Hello everyone!
I’ve been diving into the world of smart home projects lately, and it’s been an absolute blast! One of the most exciting things I’ve worked on is setting up an ESP8266 to control my garage door opener.
It’s been a fantastic learning experience, and I wanted to share my journey with you all.
Starting off, I had a spare Liftmaster remote lying around and thought, why not repurpose it? I connected it to an ESP8266, soldering a few wires and powering it through the ESP. The best part? I removed the battery from the remote, so it’s entirely powered by the ESP. This setup allows me to press the buttons programmatically without worrying about protocols or rolling codes. ![]()
Here’s a quick rundown of what I did:
- Remote + to ESP 3.3V for power
- Remote - to ESP Ground for common ground
- Remote SW4 to D5 for the big button
- Remote SW2 to D6 and Remote SW1 to D7 for the other buttons
I also integrated Aqara contact sensors to detect if the doors are open or closed. It’s been working like a charm, and I’m thrilled with how seamless the integration is. ![]()
Now, onto a common challenge I’ve come across: setting up automations that trigger if something hasn’t happened within a specific timeframe. For instance, if I haven’t pressed a single button on my Xiaomi sensor by midday, I want an alert.
I’ve been experimenting with Home Assistant’s automation rules, and while it’s a bit tricky, it’s rewarding when everything clicks into place. The key is understanding how to check for the absence of an event between two time periods without affecting other interactions. ![]()
If you’re looking to tackle similar projects, I’d recommend starting small and gradually building up. Don’t hesitate to reach out to the community for advice—it’s incredibly supportive! ![]()
Happy tinkering, everyone! ![]()
