As a homeowner who’s always on the lookout for innovative ways to enhance my smart home setup, I’ve recently been experimenting with the Shelly H&T sensor. This little device has been a game-changer for monitoring temperature and humidity in my home, and I wanted to share my experience with the community.
The Shelly H&T is incredibly easy to set up and integrates seamlessly with my existing smart home ecosystem. I’ve been using it to monitor conditions in my basement, which tends to be a bit damp. The ability to track humidity levels in real-time has been invaluable, especially during the rainy season. The sensor’s url_report feature allows it to send data to my server, which I’ve configured to trigger alerts if conditions fall outside my preferred range.
However, I’ve encountered a minor hiccup in the setup process. The sensor occasionally sends its internal ID instead of the one I’ve assigned it in my system. While this doesn’t break the functionality, it does require some extra steps to ensure the data is correctly routed. I’m curious if others have faced similar issues or if there’s a workaround to prevent the sensor from overriding the assigned ID.
One of the most impressive aspects of the Shelly H&T is its versatility. It’s not just a sensor; it’s a tool for peace of mind. Knowing that my home’s environment is being monitored 24/7 gives me confidence, especially when I’m away for extended periods. The sensor’s compact design and energy efficiency also make it a practical addition to any smart home setup.
If you’re considering adding a temperature and humidity sensor to your smart home, I highly recommend giving the Shelly H&T a try. It’s affordable, reliable, and packed with features that make it a standout product. Plus, the active community support ensures that any questions or issues you encounter can be quickly addressed.
Have you had experience with the Shelly H&T or similar sensors? I’d love to hear your thoughts and any tips you might have for optimizing its performance! ![]()
