I’ve been diving into the world of smart home gadgets lately, and I must say, it’s been an exciting ride! One of the first things I came across was theCriwi bulbs. I’ve seen some glowing reviews about them, but I was curious—are they really worth the hype? After doing a bit of research, I decided to give them a try, and I must say, I’m impressed with their performance and energy efficiency. It’s been a great addition to my home setup!
Another area I’ve been exploring is security. I recently set up a Nuki lock, and while it’s been mostly smooth sailing, I came across a minor hiccup. I wanted to integrate it with a door sensor that’s not from Nuki. Initially, I faced some issues with the Lock’n Go timer not canceling properly before it runs out. After a bit of troubleshooting, I figured out a workaround by adjusting the API settings, which resolved the problem. It’s all about learning and adapting, right?
Timing things around the house has also been a fun challenge. I needed a rule to turn on a wall plug every hour for exactly 5 minutes. My initial approach was to set up two separate rules—one to turn it on and another to turn it off after 5 minutes. It worked, but I wondered if there was a more efficient way. After some digging, I found a smarter approach using a single rule with a built-in timer. It’s much cleaner and less error-prone!
I also wanted to share a quick tip for anyone dealing withShelly 2.5 switches. I noticed a slight delay when controlling them via theShelly app orAlexa. It turned out to be related to the cloud processing. Switching to the local web interface made everything instantaneous. It’s a small tweak, but it makes a big difference in user experience.
Lastly, I’ve been eyeing theRGBWW bulbs for their versatility in lighting. They offer a wide range of colors and brightness levels, which can really transform a room. While they might seem like a splurge, the ability to set the perfect ambiance for any occasion makes them a worthwhile investment.
This journey into smart home tech has been both challenging and rewarding. It’s all about experimenting, learning from each experience, and finding the right balance that works for your lifestyle. Here’s to many more discoveries and improvements in the future!
