I’ve been diving into the world of smart irrigation and thought I’d share my journey with you all. My goal is to automate my backyard sprinklers to ensure efficient water usage, especially given the varying water pressures in my area. I’ve set up a system where only one sprinkler can be active at a time, and I’m using OpenHAB 3 to manage this setup.
Initially, I relied on a rule-based system in OpenHAB 2.5, which worked but felt a bit clunky. I’ve heard that OH3 offers more streamlined solutions, so I’m eager to explore those. My current setup uses a series of timers to cycle through each sprinkler valve after a defined period. While this works, I’m curious if there’s a more elegant way to handle the interlock functionality without manually toggling each valve.
One challenge I’ve encountered is ensuring smooth transitions between valves. I’ve found that using a combination of time-based triggers and state monitoring helps prevent overlap, but I’m still tweaking the timing intervals for optimal performance. I’d love to hear if anyone has implemented a similar system or has suggestions for improvement.
This project has been a great learning experience, and I’m excited to see how I can further optimize it. Whether it’s through exploring new features in OH3 or integrating additional sensors, there’s always something new to discover in the world of smart irrigation. If anyone has tips or alternative approaches, I’d be thrilled to hear them!
