Exploring Smart Lighting Automation with ESPHome
I’ve been diving into the world of smart lighting automation using ESPHome, and it’s been an incredible journey. I recently set up a NodeMCU-based sensor node in my bedroom to monitor temperature, humidity, and motion. The setup has been a great learning experience, though I did run into a few hiccups along the way.
One of the challenges I faced was controlling the onboard LED on my NodeMCU. After some research, I discovered that it’s possible to configure the LED using ESPHome, but getting it to work smoothly took some trial and error. I ended up using the PWM output feature to dim the LED based on motion sensor readings, which adds a nice touch to my setup.
Another interesting project I’m working on is creating a scene that transitions lights slowly when I wake up in the middle of the night. This involves setting up multiple triggers and conditions to ensure the lights only turn on if it’s dark outside and I’m actually in the room. It’s been a great way to experiment with ESPHome’s automation capabilities.
I’d love to hear from others who are also exploring smart lighting and automation. What projects are you working on, and what tips or tricks have you discovered along the way?
