I’ve always been fascinated by the potential of smart lighting to enhance my home experience. Recently, I decided to dive into creating a more dynamic and automated lighting setup using Govee and Shelly devices. Let me share my journey and some tips for anyone looking to do something similar!
The Project: Automating Outdoor Lighting with Govee
I recently purchased the Govee Permanent Outdoor Lights 2 (150ft version) and installed them around my backyard. The goal was to create a stunning light display that could be easily controlled and customized. After a few days of perfect operation, I noticed an issue where only the first two strings of lights were working, while the others remained dark. This was disappointing, but I took it as an opportunity to troubleshoot and learn more about the system.
After some research and reaching out to the community, I discovered that this issue might be related to the power supply setup. I decided to explore the possibility of adding an additional power supply to ensure all lights received consistent power. This approach not only resolved the issue but also gave me the flexibility to sync the lights more effectively through the Govee app.
Shelly Devices for Smart Automation
In addition to the Govee lights, I’ve been experimenting with Shelly devices to create a more integrated smart home ecosystem. For instance, I’ve been using a Shelly 1 to control my pool lights. Initially, I encountered some connectivity issues when closing the device enclosure, but I found a simple solution by adjusting the placement of the Shelly unit to ensure stable connectivity.
To take things a step further, I’ve set up a time-based automation using Shelly’s capabilities. Now, my pool lights automatically turn on at sunset and adjust their brightness based on motion sensor input. This integration has been a game-changer for creating a relaxing evening atmosphere without manual intervention.
Lessons Learned and Tips
- Power Supply Management: Always ensure that your smart lighting setup has a reliable and sufficient power supply. Adding an extra power supply can prevent issues and provide more control over your lights.
- Device Placement: When installing devices like Shelly, pay attention to their placement to avoid connectivity issues. Sometimes, a simple adjustment can make a big difference.
- Automation with Time-Based Triggers: Experiment with time-based automations to create seamless transitions between lighting states. This can enhance both functionality and aesthetics.
I’d love to hear from others who have tackled similar projects or have tips for optimizing smart lighting setups. Let’s continue to explore and innovate together!
Cheers,
