I recently embarked on a project to integrate a Philips Hue Tap Switch into my smart home setup, and I must say, it’s been an enlightening journey! The goal was to control four different lights using the tap switch, each assigned to a specific button press. While the process involved some trial and error, the end result has been nothing short of impressive.
First, I needed to figure out the IP address of my Hue Bridge and generate a username by sending a POST request. This was straightforward, and I used a simple curl command to accomplish it. Once I had the username, I could access the sensor details for the Hue Tap Switch, which was crucial for configuring it in my Home Assistant setup.
The next step was setting up the sensors in my configuration.yaml file. I created two sensor entries—one to track the button events and another to monitor the last updated time. This dual-sensor setup allowed me to accurately detect button presses and ensure the automation responded promptly.
The automation itself was a bit more complex. I wanted the tap switch to control four different lights, each assigned to a specific button. After some research, I discovered that the button events correspond to specific numerical values: 34 for button 1, 16 for button 2, 17 for button 3, and 18 for button 4. I incorporated these values into my automation script, ensuring that each button press toggled the correct light.
One challenge I encountered was the timing of the automation. Without a slight delay, the automation would sometimes trigger before the button state updated, leading to unexpected behavior. I added a 20ms delay to the automation, which resolved the issue and ensured smooth operation.
Now, with everything configured, I can walk into my living room and use the Hue Tap Switch to toggle any of the four lights with a simple press. It’s a small touch, but it adds a significant layer of convenience to my smart home setup.
If you’re looking to integrate a Hue Tap Switch into your setup, I highly recommend exploring the REST API and automation capabilities of Home Assistant. It’s a fantastic way to add custom functionality to your smart home without breaking the bank. Happy tinkering! ![]()
