I’ve been absolutely thrilled with my INNR color bulbs integrated with Hubitat. The ability to adjust hues and create ambiance is fantastic, but I’ve noticed something peculiar when changing colors. Each time I set a new hue, the bulb cycles through intermediate values before reaching the desired color. Sometimes, it doesn’t even land on the target value, which is a bit frustrating. For instance, when I tried transitioning from hue 1 to 50, the bulb never quite hit 30% as intended. I’ve checked the logs, and it seems like the bulb is making multiple attempts rather than setting the color directly. I’ve tested this with both firmware versions 2.2.3.119 and 2.2.2.129, but the issue persists. I wonder if there’s a way to bypass these intermediate steps and set the color more precisely. It would be amazing if the bulbs could transition seamlessly without those in-between adjustments. I’m curious if others have encountered this behavior or have found a workaround. Any insights or tips would be greatly appreciated!
