Exploring Smart Lighting Automation with Wyze Cam and LIFX Bulbs
Hey everyone, I’ve been diving into the world of home automation lately, and I wanted to share my experiences and a few tips I’ve picked up along the way. My goal has been to create a seamless system where my outdoor lights automatically turn on when motion is detected and then turn off after a set period of time. Sounds simple, right? But as many of you might know, sometimes the simplest tasks can be the most challenging!
I started with a Wyze Cam v3 aimed at my driveway. The idea was straightforward: detect motion, turn on the lights, and then turn them off after 10 minutes. I’m using LIFX bulbs outside, which are fantastic, but they don’t work with the Wyze app since it only communicates with Wyze products. So, I tried using IFTTT and Alexa routines, but both had their limitations. IFTTT struggled with turning the lights off after a set time, and Alexa routines only trigger on ‘detects a person’ rather than general motion. That’s frustrating because I want the lights to come on for any movement, not just when someone is detected!
After some research, I discovered that using a combination of IFTTT and Alexa with a bit of creativity could get me closer to my goal. I set up a workaround where the Wyze Cam triggers an IFTTT applet that, in turn, sends a command to Alexa to turn on the lights. Then, I used a separate routine to handle the countdown for turning them off. It’s not perfect, but it works most of the time. I’m still experimenting with different configurations to make it more reliable.
One thing I’ve learned is the importance of having a solid understanding of how different platforms integrate. For example, knowing that Alexa doesn’t support motion detection triggers for non-Wyze cameras was a key insight. It made me realize that sometimes you have to get creative with your setup. I also found that using a smart plug in conjunction with the lights could add an extra layer of control, especially if you want more granular management over the power supply.
I’d love to hear how others have tackled similar challenges. Have you found a more seamless way to handle motion-activated lighting with non-Wyze devices? Any tips on optimizing routines or workarounds would be invaluable. Let’s keep the conversation going and help each other create smarter, more efficient home systems!
Cheers,
