I’ve been diving into the world of smart lighting automation lately, and I must say, it’s been an exciting journey!
I recently set up Zigbee2MQTT to integrate my Osram 3-fach LEDVANCE Smart+ Mini Switch with my Home Assistant setup. While the installation process was straightforward, I encountered a few bumps along the way that I’d like to share and discuss with the community.
Initially, I noticed that the switch wasn’t behaving as expected. The logs showed an ‘action’ parameter changing with each button press, but I struggled to map these actions to meaningful automation triggers in Home Assistant. After some research and experimentation, I discovered that the ‘action’ parameter could be leveraged to create dynamic automations based on single, double, or long presses of the switch. This realization opened up a whole new realm of possibilities for controlling my smart lights!
Here’s a quick tip for anyone looking to achieve similar functionality: Instead of relying solely on the default Home Assistant integrations, consider using the MQTT trigger in your automations. This allows you to directly respond to the ‘action’ parameter changes detected by Zigbee2MQTT. For example, you can set up a rule where a single press turns the lights on, a double press adjusts the brightness, and a long press changes the color temperature. The flexibility is incredible!
Another thing I’d like to highlight is the importance of proper configuration and logging. By carefully monitoring the MQTT messages and ensuring that all parameters are correctly interpreted, I was able to troubleshoot and refine my setup. It’s also worth mentioning that the Zigbee2MQTT community and documentation have been invaluable resources throughout this process.
If anyone has tips or alternative approaches for handling multi-action switches, I’d love to hear them! Let’s continue to explore and innovate together in the world of smart lighting automation. ![]()
