Exploring Smart Lighting Integration with AppleScript
Hey everyone, I’ve been diving into the world of smart lighting and automation lately, and I wanted to share my experiences and some tips I’ve picked up along the way. I recently set up several Tradfri bulbs on my Hue bridge, and while they work perfectly with my iOS apps for color changes and routines, I encountered a bit of a hiccup when trying to use AppleScript for more advanced automation tasks.
The Challenge: I noticed that while the Tradfri bulbs responded well to brightness adjustments, they weren’t changing colors as expected when using my AppleScript setup. The color parameter (hue) seemed to be ignored, and the bulbs stuck to their last color setting. This was a bit puzzling, as I was under the impression that Hue and Tradfri bulbs should be compatible with such scripts.
The Solution: After some digging and reaching out to the community, I realized that the issue might be related to how the hue value is interpreted by the Tradfri bulbs. I adjusted the script to include additional parameters and ensure the values were within the expected range. Here’s a snippet of the revised script that worked for me:
global BridgeAddress
global apiKey
set BridgeAddress to “192.168.1.9”
set apiKey to “newdeveloper”
global turnOn
set turnOn to the quoted form of “{"on": true, "hue":47125, "sat":253, "bri":10, "transitiontime":30}”
do shell script “curl --request PUT --data " & turnOn & " http://” & BridgeAddress & “/api/” & apiKey & “/lights/15/state/”
Key Takeaways:
  • Ensure all parameters (hue, sat, bri) are within the valid range for your bulbs.
  • Double-check the API documentation for any specific requirements or quirks with your bulb brand.
  • Don’t hesitate to reach out to the community for advice—sometimes a fresh pair of eyes can spot the issue quickly!
Final Thoughts: While the initial hiccup was a bit frustrating, it was a great learning experience. It also highlighted how versatile and customizable smart lighting can be with the right scripting and automation tools. If anyone else is experimenting with AppleScript or similar tools for their smart home setup, I’d love to hear about your experiences and any tips you’ve picked up along the way!
Happy automating everyone! :blush:
