I’ve been diving into the world of smart lighting lately, and it’s been quite the journey! I wanted to share my experiences in case anyone else is looking to integrate Fibaro dimmers with Hue bulbs, as I know this can be a bit tricky.
My Setup
I recently installed Fibaro dimmers behind my wall switches, aiming to control both traditional dumb lights and my Hue bulbs. The idea was to have seamless integration where each switch controls its respective lights without any interference. However, I quickly realized that combining these two systems wasn’t as straightforward as I hoped.
Challenges Faced
One of the main issues I encountered was the compatibility between Fibaro dimmers and Hue bulbs. I read in several forums that they don’t play well together, especially when it comes to physical switches. This meant that if I used a switch to turn off a Hue bulb, I couldn’t control it via my smart home app anymore. It was frustrating, to say the least!
The Solution
After some research and trial and error, I found a workaround. By dedicating specific switches solely to my Hue bulbs and configuring them as on/off switches rather than dimmers, I was able to maintain control through my app. For the Fibaro dimmers, I ensured they were paired with the dumb lights, allowing me to adjust brightness smoothly.
Lessons Learned
This experience taught me the importance of separating smart and traditional lighting systems when using different brands. It also highlighted the need for careful planning when setting up automations. While it took some time to get everything working seamlessly, the result is a functional and user-friendly smart lighting setup.
Pro Tip
If you’re looking to combine Fibaro dimmers with Hue bulbs, consider using dedicated switches for each system. This prevents conflicts and ensures all your devices remain controllable through your preferred platform.
I’d love to hear how others have tackled similar integration challenges! Happy smartening! ![]()
