Recently, I’ve been diving into the world of smart lighting, and I must say, it’s been an exciting journey!
I’ve managed to integrate my Philips Hue Semeru table lamps with a Shelly Dimmer 2, and it’s been a game-changer for my home setup. However, I encountered a few hurdles along the way that I thought I’d share, in case anyone else is going through similar challenges.
One of the main issues I faced was getting the dimming functionality to work smoothly. I wanted to control the brightness using the Shelly Dimmer, but the initial setup didn’t quite hit the mark. After some research and tinkering, I discovered that adjusting the system variables and using a while loop in my code was the key. Here’s a snippet of what worked for me:
javascript
while (dom.GetObject(“WzDimIsActiv”).Value() && brightness > 1) {
brightness = brightness - 1;
exec = "curl " + ip + “/light/0?brightness=” + brightness;
system.Exec(exec);
This code adjusts the brightness gradually, which was exactly what I was aiming for. However, I ran into a snag where the system variable wasn’t updating as expected. After reaching out to the community, I realized that the order of operations needed a tweak. Ensuring that the variable updates happened before the brightness adjustment made all the difference!
Another thing I’ve been experimenting with is creating dynamic lighting scenes. I’ve been using the Philips Hue’s color-changing capabilities to set the mood in different rooms. It’s amazing how a simple adjustment in color temperature can completely transform a space. For instance, warm tones in the living room create a cozy atmosphere, while cooler tones in the study help with focus.
I’d love to hear from others who’ve integrated multiple smart lighting devices. What challenges did you face, and how did you overcome them? Are there any tips or tricks you’d recommend for someone just starting out? Let’s keep the conversation going! ![]()
Happy smart lighting! ![]()
