As I continue to expand my smart home setup, integrating various devices from different brands has been both exciting and challenging. One area I’ve been particularly focused on is smart lighting, specifically using Shelly devices alongside my OpenHAB system. Let me share some of my experiences and insights.Getting Started with Shelly Devices I recently added a Shelly 1 to my setup, aiming to control a 12V device. After setting up the hardware, I encountered some unexpected behavior. Initially, everything worked smoothly, but after enabling the input functionality, the device became unstable. It would work for a few minutes before losing connection, requiring a restart. This was frustrating, especially since I had another Shelly 1 exhibiting the same issue. I reached out to the community for advice, and it turns out this behavior might be related to how the input functionality interacts with the Shelly’s firmware. I’m currently exploring firmware updates and configurations to resolve this.OpenHAB Integration and Custom Rules On the OpenHAB front, I’ve been working on creating custom rules to automate my lighting system. One goal is to have my outdoor lights turn on at sunset and off at sunrise, but I’ve noticed inconsistencies in the timing. After some research, I realized this might be due to duplicate schedules in my configuration. I’ve since deleted and re-added my schedules, but the issue persists. I’m considering whether this is a known bug or if there’s a workaround I can implement.Shelly Motion 2: A Closer Look Another device I’ve been experimenting with is the Shelly Motion 2. I’m curious about its sleep mode functionality compared to the older Shelly Motion. From what I gather, the Shelly Motion 2 does have a sleep mode, but its behavior might vary depending on usage patterns. I’m planning to test this extensively to see if it meets my needs for energy efficiency and reliability.Tips and Tricks For anyone looking to integrate multiple devices, here’s a tip: always check firmware versions and ensure compatibility. Also, when setting up custom rules, start simple and gradually add complexity. This approach helps identify issues early on.Overall, while there are challenges, the journey of integrating different smart home devices is rewarding. Each problem solved brings me closer to my goal of a seamless, automated home environment. I’m excited to continue exploring and refining my setup!
