I’ve been on a journey to make my home smarter, and one of the most exciting projects has been integrating smart lighting. After some research, I decided to go with the Shelly Dimmer 2 for my kitchen and bathroom lights. The setup was straightforward, and the integration with Home Assistant has been seamless. However, I encountered a bit of a challenge when it came to installing the dimmer in my hallway, which uses a three-way switch setup.
The installation process was a bit confusing at first. I followed the instructions to connect the dimmer to the switch, but I noticed some odd behavior. The dimmer would only respond every other time I pressed the switch, and the energy consumption readings were consistently showing zero. After some troubleshooting, I realized the issue was with the wiring configuration. The dimmer needed to be connected differently to account for the three-way setup.
After a bit of trial and error, I managed to get it working properly. The key was ensuring that the dimmer was connected to the correct terminals and that the power supply was correctly routed. Now, the dimmer works perfectly, and the energy consumption readings are accurate. It’s been a great learning experience, and I’m thrilled with how my lights are now fully integrated into my smart home ecosystem.
For anyone else looking to install a Shelly Dimmer 2 in a multi-switch setup, I’d recommend carefully reviewing the wiring diagram and ensuring all connections are secure. A little patience goes a long way in getting everything set up correctly!
