As I delve deeper into the world of smart lighting, I find myself at a crossroads, weighing the pros and cons of different systems. My journey began with the Osram/Lightify system, which, while promising, has been fraught with challenges. From bulbs dropping out of the network to the constant need for re-pairing, it’s been nothing short of frustrating. Despite these hurdles, I managed to set up a system using two Hubitat hubs—one for the bulbs and another for the sensors. However, the experience hasn’t been seamless, especially with the sheer number of bulbs in my setup (around 25). The system often struggles to keep up, particularly when it comes to dimming, and the Lightify remotes have proven to be battery hogs, requiring frequent replacements.
After much deliberation, I’m considering making the switch to the Lutron Caseta system. The promise of reliable performance and the ability to integrate with my existing Hubitat setup is appealing. My lighting configuration is quite unique, with each branch controlled by a remote latching relay and a low-voltage switch. This setup means there are no conventional wall switches to work with, which has been a limitation in the past. The Caseta system, with its smart dimmers and wireless remotes, seems like a potential solution. I plan to install these dimmers in code-legal boxes in my attic, using the wireless remotes to control them. The idea is to also link this system with my Hubitat hubs for seamless integration.
However, there are concerns. The Caseta literature mentions avoiding flickering and ghosting without using ELV or Pro dimmers, but I’m not entirely sure how effective this will be with my LED bulbs. Additionally, with the number of dimmers and remotes I need (around 9 dimmers and a dozen remotes), I’m wondering if I’ll need a repeater for the Caseta system or another Hubitat hub to manage the expanded setup. The cost is another factor, but the potential for a more reliable system might justify the investment.
I’m also curious about others’ experiences with the Caseta system, especially in similar configurations. Have you managed to integrate Caseta with Hubitat without issues? How have you handled the wireless range and the number of devices? Any insights or tips would be invaluable as I navigate this transition. The goal is to create a smart lighting system that’s not just functional but also resilient, minimizing the dropout problems I’ve faced with Lightify. Here’s hoping the Caseta system can deliver on its promises and provide the reliability I’ve been seeking.
